Results 1 to 17 of 17
    Default Android OS Top of S5 Battery Stats
    So, I had my phone in my pocket during dinner and checked it out later aftwrward, and the Android system was consuming most of the battery. Anyone know of any reason why?
    Attached Thumbnails Attached Thumbnails Android OS Top of S5 Battery Stats-screenshot_2014-08-05-19-32-13.jpg   Android OS Top of S5 Battery Stats-screenshot_2014-08-05-19-32-08.jpg   Android OS Top of S5 Battery Stats-screenshot_2014-08-05-19-31-58.jpg
  2. #2
    jdmorin's Avatar
    Posts
    Global Posts
    175 Global Posts
    Default re: Android OS Top of S5 Battery Stats
    I'll bet it kept turning on in your pocket. Just a guess. I've had that a few times.
    I'm just going on the fact that your screen is 29% with 3.5 hours of on time.
  3. #3
    Do you have sync on?
    That might be the main culprit.
    Posted via my Galaxy S5
    Quote Originally Posted by charlee08 View Post
    I don't think I do? Is there an app that syncs or a function somewhere in settings? Because I've already disabled most of that stuff.
  5. #5
    Just pull down your quick setting at the top of the screen and see if sync is lit up or not.
    Found it in all of the other toggles. Thank you a lot!
    I'm such a noob at Samsung phones haha.
  8. #8
    With sync off you'll have to check your email manually, as it won't push through anymore. But you can turn it on while the phone is charging or something and let it back up things to your Google account.
    Okay, so email. What about other social media?
  10. Thread Author  Thread Author    #10
    Quote Originally Posted by jdmorin View Post
    No I used it haha it doesn't turn on in my pocket.
  11. #11
    Quote Originally Posted by AKFL3TCH3R View Post
    You can goto your settings screen and scroll down to "Accounts" and see what all you will be turning off.
    But no, it won't affect getting social media notifications.
  12. #12
    I don't really know what you're expecting. The phone is only coming on when you have the screen on, I don't think it's a sync "issue." Being down to 30% after 8 hours of pretty heavy use and 3.5 hours of screen time seems normal. If you'll look at your graph, you'll see the battery barely drains when you aren't actually using the phone.
  13. Thread Author  Thread Author    #13
    Quote Originally Posted by jonebk12 View Post
    Sorry I was just curious about my new phone -_-
  14. #14
    No need to apolgize, I just wanted to point out that your battery life seems pretty solid from my experience and that I don't think turning off sync will do you much good.
  15. Thread Author  Thread Author    #15
    Okay haha.
  16. Thread Author  Thread Author    #16
    Would anyone recommend turning off the LED capacitive button lights? Or does it not rally matter?
  17. #17
    Aquila's Avatar
    Gonfaloniere
    Posts
    Global Posts
    13,587 Global Posts
    Carrier
    Assassin 'Droid
    Wouldn't be too worried as the device awake times sync up great with screen on. Android OS taking up that much is not bad in and of itself - it's only bad if something is wrong. A device that is left mostly idle will have skewed stats relative to the percentage of battery life used when compared to one that is frequently used for many different apps, etc.
  1. Replies: 8
    Last Post: 08-28-2014, 01:41 PM
  2. Replies: 89
    Last Post: 08-19-2014, 11:47 AM
  3. Replies: 3
    Last Post: 08-07-2014, 12:57 PM
  4. Replies: 7
    Last Post: 08-07-2014, 03:43 AM
  5. Android wear keyboard?
    By dhawk1202 in forum Android Wear
    Last Post: 08-06-2014, 10:43 PM
