1. blevitt3's Avatar
    My son and I both recently got the S5. Today his phone completely drained and shut off, even though he was at work all day. I compared Battery settings on the 2 phones and saw where his "Android System" settings show 48% usage where mine is 14%. I'm new to Android so would appreciate any info...
    08-07-2014 12:36 AM
  2. blevitt3's Avatar
    He just went in and disabled several apps...possibly that will help?
    08-07-2014 12:39 AM
  3. B. Diddy's Avatar
    Battery drain like that can be due to a number of issues--most often, an app or process that is running out of control. A reboot usually corrects things, but it can be difficult to pinpoint what is causing the drain. Another notorious battery suck is poor cell signal. It would be helpful to see screenshots of the Battery stats (Settings>Battery), as well as the full screen battery graph (to see the total Awake time and the Cell Signal strength), the Screen category (to see the total Screen On time), and the Cell Standby category (to see the Time without Signal).
    08-07-2014 12:42 AM
  4. AZgl1500's Avatar
    I work in very rural areas on a road crew. We are constantly going down into deep ravines and staying there for hours.
    Cell sites disappear or are very weak.
    I use MacroDroid to turn off Data, Wifi when the phone's screen is locked.
    When the screen is unlocked, I have it automatically turn on Data and Wifi.
    * MacroDroid - Device Automation - Android Apps on Google Play
    Taking over the phone's access to the internet stopped my phone from wasting battery power needlessly.
    The phone will now last me 3 to 5 days or more easily. It is currently at 64% after 3-1/2 days off charge.
    I do a lot of newspaper reading and all of their videos, emails, and a lot of texting.
    I also have the screen set at 10 minutes to make reading easier.
    Just tap the Power Button and the screen is locked instantly (settings for that in Lockscreen)
    08-07-2014 05:34 AM
  1. New G3 - Weather app battery draining
    By Shlomey Derhi in forum LG G3
    Last Post: 08-15-2014, 12:55 AM
  2. better performance with less power
    By jimmytan45 in forum General News & Discussion
    Last Post: 08-06-2014, 02:16 PM
  3. The Power Button locks my Samsung
    By Chili in forum Ask a Question
    Last Post: 08-06-2014, 09:12 AM
  4. The Power Button locks my Samsung
    By saachi.sennik@gmail.com in forum Ask a Question
    Last Post: 08-06-2014, 09:03 AM
  5. connection between battery drain and motherboard.
    Last Post: 08-06-2014, 05:08 AM
