Results 1 to 9 of 9
    Repoman23's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy S5 battery problems, please help.
    Hi guys, I know this topic gets asked about alot in these forums, but I don't know who else to ask for advice. I've had my S5 since it came out, and the only reason I bought was because the battery life was supposed to be awesome. After having the phone for a little while, I'm noticing that is has a worse battery life than my old iphone 4s. I took the phone back to the store I bought it from, but they insist nothing is wrong with my phone and that I'm just too picky. Here are the screenshots on my battery today,can anyone suggest a way to make its life last as long as it should?
    Attached Thumbnails Attached Thumbnails Galaxy S5 battery problems, please help.-2014-08-15-22.39.33.jpg   Galaxy S5 battery problems, please help.-2014-08-15-22.39.24.jpg   Galaxy S5 battery problems, please help.-2014-08-15-22.39.49.jpg   Galaxy S5 battery problems, please help.-2014-08-15-22.56.48.jpg   Galaxy S5 battery problems, please help.-2014-08-15-22.56.53.jpg
  2. #2
    PainFX's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S5 battery problems, please help.
    what is your screen time?
    Repoman23's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    right at an hour.
  4. #4
    PainFX's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    go into application manager and start turning off apps and force stop apps. it helps.
  5. #5
    codyoehl's Avatar
    Posts
    Global Posts
    595 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would turn on power saving mode, turn off Bluetooth, turn off location settings, use wifi if you can, turn off cellular data if it's a bad connection or you don't need it, turn the brightness as low as you can stand it, and turn off some built in apps that are running that you don't use
    And have you also tried using a different battery?
    Posted via Android Central App with my Samsung Galaxy S5
    Repoman23's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I normally press the left button and then go to active applications and choose "end all." Does that wor? Or should I go through the application manager in the settings? Also should I be stopping all the things that are currently running, or just a few specific ones?
    Repoman23's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by codyoehl View Post
    No, I haven't tried a different battery. And I always keep regular power saving mode on.
  8. #8
    Bryan Eriksson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same here, the battery is terrible.
  9. #9
    AZgl1500's Avatar
    Posts
    Global Posts
    1,962 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Go into settings/apps/app mgr and Disable/Uninstall anything that has Amazon in the name. That app is a huge battery sucker.
    Disable any app you don't use, for me, S Health is useless so I disabled it, noticed right away that the battery life improved.
    Turn off sync, turn off Background data. Neither of those are needed for 99.5 percent of what we do.
    For myself, I turn off Data, WiFi, Sync, every time I lock the screen and the phone is idle. I choose to use MacroDroid to handle that chore for me. YMMV but it is a great app.
    Bluetooth uses a bit of power, but I leave it on because I wear a BT earpiece at work.
    GPS location uses a tiny bit of power, but I leave it on also in High Accuracy Mode. This has not been a problem for me at all. Battery Doctor reports that only costs me about 25 minutes worth of battery per day.
    I prefer to have the phone totally idled when I don't have the screen lit up and me reading something.
    Telco calls and Txt Messaging works just fine w/o any of the data services, it is a basic 1x service that rides on the carrier's basic service.
    I easily get 3 or 4 days of use when I am not really active with the phone.
    On days when I need it, the battery is always nearly topped off at 90% plus and then I go surfing and use a lot of video, newspaper articles, realtime TV watching, etc..... when doing that I notice that the battery takes a pretty hit.... down to something like 80% or even a time or two down to 65% during a single surfing session that lasted a couple hours or more.
    Just make sure that any app you are not using is not active in the background.... when I am out on the job, I make heavy use of the GPS and reporting locations for road work repairs, bridges that have missing pavement, etc.... on those times, the battery takes a good hit because of the heavy mapping data required to be downloaded and using email to send in the reports.
    The S5's battery is a good one, I have no complaints. Originally before I bought the phone, I thought I would need one or two spare batteries. I always did in the past, but not with the S5. It has always gotten through the day with a lot of power left.
    Sometimes it is down to 15%, other days it is still st 85% or better. Just depends on how active my work load has been.
  1. My S5 will not work with Sprint Airave while in LTE/CDMA mode
    By Jason MacArthur in forum Ask a Question
    Last Post: 08-21-2014, 10:41 AM
  2. Samsung Galaxy Tab 10.1 touch screen issues
    By talosX in forum Samsung Galaxy Note 10.1
    Last Post: 08-16-2014, 08:07 PM
  3. Galaxy Tab 3 Problems after factory reset
    By Evgeniya Asenova in forum Samsung Galaxy Tab 3
    Last Post: 08-16-2014, 01:26 PM
  4. Help!! BrilliantPad 7026c wont boot!
    Last Post: 08-15-2014, 09:05 PM
  5. Samsung Galaxy Wont Fully Turn on
    By suit3dcm in forum Samsung Galaxy S4
    Last Post: 08-15-2014, 09:03 PM
