Results 1 to 3 of 3
    Question Messages+ settings problem
    Went into Settings/Sound to change a sound file for incoming messages. As soon as I select Messages I get the message "Unfortunately, Settings has stopped." It was still running, though. If I select Call, Email or Calendar it takes me to the valid next screen.
    Tried something else. Went to Settings/Applications and selected Messages. Same error message. Selecting any other option works OK.
    I had WhatsApp installed so I deleted it just in case. No fix to problem. Also cleared cache. No fix.
    The Messages+ app works fine. Seems I just can't change any settings regarding it from the Settings app.
  2. #2
    Default Re: Messages+ settings problem
    Which cache did you clear? The app cache? If so, try clearing the system cache partition: Reset: Samsung Galaxy S 5 | T-Mobile Support
    I cleared app cache, system cache and uninstalled updates to Messages+. I even reenabled VZWAVSServices. Nothing helped.
  1. AT&T s4 active with no group messaging option or capability?
    By Thepoto in forum Samsung Galaxy S4 Active
    Last Post: 08-19-2014, 03:53 AM
  2. problem with hot spot
    By vsbunker07 in forum Droid RAZR MAXX Rooting, ROMs, & Hacks
    Last Post: 08-18-2014, 06:11 PM
  3. How to set black background when browsing apps.
    By Robert Toldi in forum Samsung Galaxy S3 Mini
    Last Post: 08-18-2014, 11:47 AM
  4. Looking for an app to change lock settings
    By petvas72 in forum Ask a Question
    Last Post: 08-17-2014, 09:57 PM
  5. HTC One Car Mode tunein radio problem
    Last Post: 08-17-2014, 02:59 PM
