1. gofaulk28's Avatar
    Hi, I was hoping someone here could help me.. when I try to change my notification LED light to either orange or yellow, it shows up as green only. The red, blue, purple, etc. work correctly but not the orange or yellow.I tried using the LED tester app and when I tested the orange/yellow they still showed up as green. I can't find any info anywhere on why this would be doing this. I tried shutting the phone off and restarting, but I don't know what else to do? I really want to be able to use those colors! Thanks so much in advance. I have a galaxy s5 and verizon.
    08-17-2014 06:50 PM
  2. PsychDoc's Avatar
    Try Lite Flow from the Play Store.
    08-17-2014 07:13 PM
  3. gofaulk28's Avatar
    I just tried light flow and still didn't work. I set my texts to be orange and when I tested it the led light still shows up as green! I cannot get an orange or yellow light no matter what! Thanks anyway! I know it's just a minor annoyance, but my phone is brand new, I can't figure out what is wrong, very frustrating.
    08-17-2014 07:39 PM
  4. emilioaponte's Avatar
    Check out the screenshot.
    Sent from my Nexus 5 using Tapatalk
    08-17-2014 09:43 PM
  5. gofaulk28's Avatar
    Thanks, but I did try that app as well. Same result, when I tried to configure my message notifications to orange they still showed up as green on my phone. I just don't get it and cannot figure it out! I don't know what else to do?
    08-17-2014 10:54 PM
  6. gofaulk28's Avatar
    hanks, but I did try that app as well. Same result, when I tried to configure my message notifications to orange they still showed up as green on my phone. I just don't get it and cannot figure it out! I don't know what else to do? Its like my phone wont recognize those colors at all!
    08-17-2014 11:07 PM
  7. dadathepanda's Avatar
    Do you use a third party app for that? I'm asking because I don't see any setting where I can change the led color in the stock settings.
    08-18-2014 02:11 PM
  8. gofaulk28's Avatar
    Hi, Panda, I didn't install any apps, I use something called message plus which came with the phone. I don't know if thats 3rd party app or not? It's under the advanced settings. I actually took the phone to a Verizon store today since I work by one and they couldn't fix it either. They said the only thing they thought is that it might be is a glitch in the app and maybe it would fix itself when the app updated. I did try to uninstall and reinstall it but still didn't help. Since I do get red led (during charging) and blue led(notifications) they told me it was not the phone itself. Who knows??
    08-18-2014 02:20 PM
  1. Volume drops low, triggering notification chime fixes it?
    By gowenfawr in forum Samsung Galaxy S5
    Last Post: 08-18-2014, 06:45 PM
  2. LED notifications?!
    By gofaulk28 in forum Ask a Question
    Last Post: 08-18-2014, 02:24 AM
  3. LED notification issues htc 816
    By the rock 2016 in forum HTC Desire 816
    Last Post: 08-17-2014, 10:49 AM
  4. Notification bar
    Last Post: 08-16-2014, 10:07 AM
  5. Notification sounds
    Last Post: 08-16-2014, 07:40 AM
