Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Like Tree2Likes
    Default Battery Issues, please help!
    So I've had the S5 since its been out, and for a little while the battery life was awesome! But now, my battery almost dies every day. I took my phone back to the store asking if they could look at it and suggest anything, but they said I should be grateful that I get this much battery life out of it. I mostly use my phone for texting (which isn't alot), and listening to music. Can anyone give me their opinions and what can I do to make the battery last longer? Any advice would be greatly appreciated!
    Attached Thumbnails Attached Thumbnails Battery Issues, please help!-2014-08-19-03.57.34.jpg   Battery Issues, please help!-2014-08-19-03.57.38.jpg   Battery Issues, please help!-2014-08-19-03.57.44.jpg   Battery Issues, please help!-2014-08-19-04.01.47.jpg
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Battery Issues, please help!
    Quote Originally Posted by Repoman23 View Post
    How long has this issue been happening for you? Have you tried rebooting the device since your battery life went bad?
    Repoman23 likes this.
  3. #3
    STARGATE's Avatar
    Posts
    Global Posts
    9,223 Global Posts
    Carrier
    None
    I also have a GS5 and I normally get about 14 hours out of it with about 3-3.5 hours screen time on a 4G area.
    But I use it with the screen at 100% and plenty of emails, some of them with pictures taken that same day.
    Several texts and phone calls.
    Milk or Pandora.
    AC forums.
    A little bit of Facebook and Twitter.
    So, if you only text, I really think you should get more out of it.
    Do what UJ95x suggests, a battery pull also.
  4. #4
    Again 17hrs uptime with 2hrs+ of screen time and 30% battery left is pretty good. Nothing to worry about. Batteries degrade over time i'm afraid with each time you charge them, so it might just be a case of your particular battery not being as good as it used to be.
    Resendetra and Repoman23 like this.
    Quote Originally Posted by UJ95x View Post
    I've restarted the phone pretty often. I know thats supposed to help the battery.
  6. #6
    Three7s's Avatar
    Posts
    Global Posts
    81 Global Posts
    It looks like you are doing OK, but there is room for improvement. Without knowing how you use your smartphone, I'll make a few suggestions (that may not work for your purposes).
    Your cell signal is often weak or non-existent. This requires the phone to step up the power in order to maintain a connection. If you can't change the signal strength, consider using Airplane mode. You can still maintain the WiFi connection while the cell radio is off. This would obviously mean that you could not get phone/SMS the normal way.
    Your WiFi is always on. If you do not need it on all the time, consider turning it off. The wakelocks will be significantly reduced, but obviously this would impact getting that urgent Twitter alert from the Biebs.
    I think you would benefit from an app like Greenpower or JuiceDefender. Those can help you stretch your battery much further, depending on your needs.
    I have a list of items you can check here: TIPS to Extend Your Battery Life
    UJ95x likes this.
  7. #7
    emanwis's Avatar
    Posts
    Global Posts
    257 Global Posts
    I was worried about my battery. I switched to the S5 from the iPhone 5S on Friday. I haven't really changed any settings and now it is amazing. Right now, I'm at 83% battery remaining after unplugging my phone at 5:00 am this morning. I'm very happy!
    STARGATE likes this.
  8. #8
    I am in the same boat as you are. My phone has been off the charger for 4 hours and 44 minutes and I am down to 64%. Today I have only done text messages, checked emails, and replied to Facebook posts. 40% in 5 hours seems a bit much to me. I have noticed that the location icon kept popping up, so now location is turned off unless I need it. It's just a pain to have to keep turning it on and off. I, like you, took my phone back to the VZW store to see if there was a problem. I was losing like 5% every 30 minutes with the phone being locked. The manager said that was normal for all phones. I had just come from an iPhone 5S, and that was not normal. I've given up on looking for a solution, I just have a freaking charging cable at home, work, and in the car, and plug in whenever I can. I also bought an extra battery. I've read where some thinks it's a bug with the 4.4.2 software and it should be resolved with the 4.4.4. But who knows how long that will take to make its way down to us. Verizon is terrible about updates and who knows if that will even work.
    If I am playing games or watching videos, the battery will drain fast, which is to be expected, but if I am just texting and checking FB, there is no reason that I should lose 40% in 5 hours. My android system is at 26% usage. That just seems high to me.
  9. #9
    Rukbat's Avatar
    Posts
    Global Posts
    22,798 Global Posts
    Carrier
    Modified Stock 4.4.2
    That's another one of those stories that's not true but sticks around like glue. If you have apps running that you don't close, restarting the phone will save battery, but so will just closing the apps you're not using. (The Home button doesn't close the current app, it just runs the launcher, while leaving the current app still running.) Actually, restarting the phone wastes battery power, because it's using battery while restarting, while you're not getting any use of that power. (It's like the "put a wet phone into dry uncooked rice" nonsense. I wish there were some way we could get rid of these "told once, repeated always, never correct" instances of "expertise".)
  10. #10
    mklasse's Avatar
    Posts
    Global Posts
    59 Global Posts
    17 hours and still have 30% left actually sounds good. You said texting and listening to music, but on spotify? Spotify use data and use more juice than listening to offline music I would guess?
    I also agree that battery degrades over time. Do you let your battery very low (ie. below 10-15% charge) before you start charging your battery again? I heard that Lithium ion batteries degrades faster if you do that frequently. If not, maybe you should also try calibrating your battery?
    Either way, I don't think you should be worried too much about it, it's a good thing the battery on our phone is removable, so if it's toast, just get a new one and you're good to go. The battery is actually a lot cheaper than iPhone's and with iPhone (or any other phones with non user-removable battery) you have to bring it in to do that.
  11. #11
    I am recently having the same problem. My phone is less than 4 months old. I hardly use it, and it mostly sits on the table powered on, waiting for calls or texts. I used to get several days out of the battery under these conditions. My screen time is normally under 3%. All of a sudden it needs to be charged every day, sometimes twice, and it is warm to the touch. Something has changed.
  12. #12
    Quote Originally Posted by TMFoughty View Post
    what is your on screen time? what is your brightness level?
  13. #13
    On time was 2 hours and 4 minutes. Brightness was at 40%.
  14. #14
    Quote Originally Posted by Blobfish_Love View Post
    Charging everyday is perfectly normal.
    If its heating up when idle, that means some background process or application is using the CPU, thus battery drain. Check your batt stats for the high percentage users. Pull the battery overnight. Follow basic power saving techniques posted all over this site. Check to see if your cell signal isn't very weak. Try another new battery, they're cheap to buy now. I pulled my battery overnight recently, probably just coincidence but i'm getting much better batt life now. Getting 24hrs uptime and 4.5hrs screen time with 15% charge left regularly now.
  15. #15
    sirmaru's Avatar
    Posts
    Global Posts
    265 Global Posts
    If you go into Ultra Power Saving Mode when not in use, all apps are shut down other than phone calls and messaging. Rogue apps will also be shut down and will not come back until activated.
  16. #16
    turn off wifi and mobile data while the phone is sleeping see if it stop.
  17. #17
    I have almost the same usage stats as you but my battery would be dead before 12 hours of up time Some days I need to charge it twice with only moderate usage. I think there are some apps running in the background that wake the phone up that we are not aware of. I'm going to factory reset soon and slowly start re-installing my apps to see if any specific apps are to blame.
    I'll keep you posted.
  18. #18
    Here are a few of my stats
    Attached Thumbnails Attached Thumbnails Battery Issues, please help!-screenshot_2014-08-22-11-28-25.jpg   Battery Issues, please help!-screenshot_2014-08-22-11-28-15.jpg
  19. #19
    Barely any screen time. Battery at 26% now.
    Attached Thumbnails Attached Thumbnails Battery Issues, please help!-screenshot_2014-08-22-12-51-27.jpg   Battery Issues, please help!-screenshot_2014-08-22-12-53-06.jpg
  20. #20
    Quote Originally Posted by Bryan Eriksson View Post
    Turn OFF your WIFI and Mobile DATA while the phone is asleep.
  21. #21
    Quote Originally Posted by bIOforger View Post
    You're incorrect. It's NOT normal to have to charge the phone every day when it sits on a table, unused. I was getting more than 2 days out of the battery under such use, and that was making a couple phone calls, etc. Something changed in the phone. What I recently realized is that, on the pull down menu, there's a footer at the very bottom which shows the service provider, in my case T-Mobile. Lately, instead of saying T-Mobile, it was stuck on "Searching". I am convinced that my phone was doing something weird, trying to find a better connection or something. Now it's back to saying T-Mobile, and the battery drain has stopped and it is no longer warm.
  22. #22
    So I factory reset my S5 but the battery is still subpar.
    Attached Thumbnails Attached Thumbnails Battery Issues, please help!-screenshot_2014-08-23-23-37-30.jpg   Battery Issues, please help!-screenshot_2014-08-23-23-37-37.jpg   Battery Issues, please help!-screenshot_2014-08-23-23-38-25.jpg   Battery Issues, please help!-screenshot_2014-08-23-23-38-29.jpg
  23. #23
    When you pull down the notification bar and it says "searching" or on the top of the phone it has an icon, "O" with a slash in the middle, that means you don't have reception or no service. If you got your mobile data turned on during that time, LTE is stressing out to get signal, hence the drain..
  24. #24
    Quote Originally Posted by PainFX View Post
    Here's the thing- mobile data is turned OFF. All of this talk of turn this off, turn that off, disable bloatware, this, that, the other thing is meaningless. This problem has nothing to do with that. All of that stuff has been running since I bought the phone, I never had any battery problems, and all of a sudden within the last two weeks, the phone went into a state of massive battery drain. This phone is still in its factory state. I have installed no apps, nothing. I have a Samsung S3 as well, which has a weaker battery since it's been used 1 1/2 years longer than this new phone, and it will sit, with WIFI on, and everything else on too, GPS, etc., and it lasts close to 4 days, just like this S5 used to. Now, I cannot even go to bed with less than 60% charge or it will be dead in 8 hours time. "Android System" is the culprit, and I have no idea why. I found countless other posts on other sites about this exact same issue, and nobody has found the cause, or a solution. It is an operating system issue. Despicable and unacceptable for such an expensive unit.
    Oh, and I should mention that this has nothing to do with the Samsung, because it's across all android based phones.
  25. #25
    1Coopgt's Avatar
    Posts
    Global Posts
    637 Global Posts
    Follow the directions below and try clearing the cache . See if that helps . My Razr Maxx use to get weird once in a while and start draining the battery for no reason . Clearing out the cache usually fixed it . Good luck .
    Turn off the device.
    Press and hold the following three buttons at the same time:
    Volume Up key
    Home key
    Power key
    When the phone vibrates, let go of the Power key but continue to press and hold the Volume Up key and the Home key.
    When the Android System Recovery screen appears, release the Volume Up and Home keys.
    Press the Volume Down key to highlight 'wipe cache partition.'
    Press the Power key to select.
    When the wipe cache partition is complete, 'Reboot system now' is highlighted.
    Press the Power key to restart the device.
  1. Real or Fake GS5 need help ASAP
    By Lopeza90 in forum Ask a Question
    Last Post: 03-21-2015, 03:05 PM
  2. Lost/Deleted Music, need help
    By Christopher Brett in forum Ask a Question
    Last Post: 08-22-2014, 02:46 AM
  3. Replies: 3
    Last Post: 08-21-2014, 04:19 PM
  4. I need help flashing a rom via TWRP, I have wiped my original operating system
    By Brian White7 in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 08-19-2014, 12:48 AM
  5. Replies: 1
    Last Post: 08-18-2014, 11:11 PM
