Results 1 to 3 of 3
    bbmjack's Avatar
    Posts
    Global Posts
    811 Global Posts
    Default big problem
    My phone screen won't turn on but I can see LED light I have to remove battery to make phone work normally for 20 minutes or if I don't use it
    Is it because I dropped water on it ?
    Or normal
  2. #2
    Default Re: big problem
    So when you do a battery pull, it works normally for about 20 minutes, then the screen blacks out again? How much water did you drop on it? This is clearly not normal behavior. A few things to try:
    1. Unmount and remove the external microSD card, in case it's corrupt.
    2. Boot into Safe Mode, to see if something you installed is causing issues. If the problem resolves in Safe Mode, then you know that something you installed is the culprit.
    3. Boot into Recovery Mode and wipe the cache partition.
    Instructions for #2 & #3 are here: Reset: Samsung Galaxy S 5 | T-Mobile Support
    bbmjack's Avatar
    Posts
    Global Posts
    811 Global Posts
    4 seconds in 7 cm water and was stuck in headphone jack but it's fine
    I will see later today
  1. G3 Chromecast Connection Problem
    By mlett in forum LG G3
    Last Post: 02-07-2015, 03:53 PM
  2. Replies: 4
    Last Post: 08-25-2014, 05:23 AM
  3. USB connect problem -- not recognized
    By linter in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-25-2014, 02:14 AM
  4. Note 3 buggy charging problem
    By Kay Ray in forum Samsung Galaxy Note 3
    Last Post: 08-20-2014, 07:53 PM
  5. note 3 quick glance problem
    By marselisgn3 in forum Samsung Galaxy Note 3
    Last Post: 08-20-2014, 04:31 PM
