1. Desertnate's Avatar
    After switching to a S5 from the iOS platform I thought I had a really good handle on running the new device until one of the most simple functions on any phone decided to cause me the most grief. I've installed a new launcher, customized the icons, and tweaked hundreds of settings, but I've been bested by the volume control.
    Primary issue: When I increase the volume using the rocker on the side of the phone, it only applies the change to incoming calls only, not incoming text message notifications. I'm constantly missing texts because I never heard them come in. I can't see any separate setting anywhere. Did I overlook it?
    Secondary issue: Volume levels for both messaging and phone calls seems to randomy set themselves. Some times off...sometimes medium...sometimes very soft. It's almost as if it changes everything I unlock the phone. Am I missing something?
    Thanks,
    08-27-2014 09:48 PM
  2. emanwis's Avatar
    Settings --> sound --> volume. You can manage volume for ringtone, media, notifications separately.
  3. sartick's Avatar
    I have a similar question.....can I have one volume level for my ringtone(s) and a different level for the call itself?
    08-28-2014 06:24 AM
  4. ABOSWORTH007's Avatar
    Thanks,
    When you hit the volume button, a little box comes up. Tap on the gear and you will get separate volume sliders for Ringtones, Notifications, Media and System.
    08-28-2014 07:04 AM
  5. emanwis's Avatar
    08-28-2014 09:24 AM
  6. srkmagnus's Avatar
    You might need to use an App called Tasker to set that. Not sure if it will, but it's very versatile and likely could.
    OP, as mentioned above you'll need to go into settings > sounds and adjust the various sounds accordingly. There are widgets in the Play Store that will allow you to control each individual volume without changing the device wide volume setting. Take a look at that and let us know how it works for you.
    08-28-2014 10:20 AM
  7. 1Coopgt's Avatar
    Thanks,
    This app will fix you up . It has a a widget also which you can control all of your volume settings from . https://play.google.com/store/apps/d...lumePlus&hl=en
    Attached Thumbnails Separate volume settings for msg notifications & ring tone?-2014-08-28-18.29.46.jpg   Separate volume settings for msg notifications & ring tone?-2014-08-28-18.29.50.jpg
    08-28-2014 01:28 PM
  8. sartick's Avatar
    I found an app named Persist that allows you to set a specific volume level for virtually all the things on your phone that have sound associated with it. From what I have seen and tried, it works well. Persists allows you to set specific volume for:
    Alarm
    Media
    Ringer
    Notification
    System
    Voice (i.e. phone calls)
    Bluetooth
    Each has a volume bar associated with it. To increase a specific volume, an upward flick of your finger on that bar will increase that volume while a downward flick will decrease that volume setting. The app is free and seems to do all that I wanted to do. They have a Pro version ($2.99, I think) that claims to have additional features.
    08-29-2014 10:52 AM
  1. Headset volume warning
    By cydewaze in forum Samsung Galaxy S5
    Last Post: 09-25-2014, 06:58 AM
  2. Looking for a watch to do the following
    By mikejnger#AC in forum Android Wear
    Last Post: 09-24-2014, 08:51 AM
