Water damage indicator - where is it located?
bbmjack
664
Re: Water damage indicator.
If you remove battery you will see little square next to serial number and the battery have it as well
Normal one is pure white some phones have purple x
Red square is damage indicator
khainguyen97
Active member
May 5, 2014
44
Not really water resistance....
I was washing my phone with the back cover and case on. After that, I opened the back cover and notice that both water damage indicator, 1 on the phone, 1 on the battery turned red. I didn't submerged the whole phone into the water. How can that happened? But it still working...
khainguyen97
Active member
May 5, 2014
44
Is there any water damage indicator inside the phone?
bbmjack
664
There Is one remove the battery you will see white small square
bbmjack
664
Re: Not really water resistance....
Ok let's start now. You sure that back cover fully sealed 100% ? And usb cover fully closed ?
khainguyen97
Active member
May 5, 2014
44
Interesting... did you wash your phone before and didn't open your cover If so water went in the device you did it now again
I wash it before, but the water didnt went in, until now. Maybe the rubber that keep the water from getting in has problem. But I am glad that the phone still working fine.
bbmjack
664
I think your rubber has changed did you play on the rubber ?
bbmjack
664
See this holes? That's whu
