1. AC Question's Avatar
    Hey Guys I have a galaxy s5 internationally unlocked version! It should support 4G LTE since it has Tmobiles bands. I set it to LTE/WCDMA/GSM since that was the only option that has LTE in it but I have never been able to connect to LTE. I'm usually alway on EDGE or HSPA or HSPA+. I wanna be able to connect to 4G or 4G LTE. Can you guys help me fix this problem? I'm kinda a noob at this so please explain.! Thanks!
    08-28-2014 01:43 PM
  2. UJ95x's Avatar
    Welcome to AC
    Have you checked that it supports all of the same LTE bands? If it only has some, then you might just not be in a market where they aren't using one of the supported bands.
    Is there anyone else with a T-Mobile S5 you can compare with to see if they are getting LTE?
    08-28-2014 09:42 PM
  3. Calliibro92's Avatar
    hey guys ive seen this problems on my phone too i'm still getiing only h+ not the lte or 4g im trying to fix this problem ive found out a lot speaking on this so you need to follow some steps it might work for you (it didn't for me ) so in the dialar type this *#0011# and then a menu will come up press the right corner on the tree buton slect (back) then select (key input) type capital (Q) the pres the right buton again press key input and dial 0000 and after 10 seconds a menu will appear check the video
    06-26-2016 12:45 PM
  4. B. Diddy's Avatar
    According to the specs, the only overlap that the G900F has with T-Mobile's LTE spectrum is with Band 2, which is not a major band for T-Mobile. Band 4 is T-Mobile's backbone, and Band 12 is growing, neither of which is supported by the G900F.
    Samsung Galaxy S5 - Full phone specifications
    Cheat sheet: which 4G LTE bands do AT&T, Verizon, T-Mobile and Sprint use in the USA?
    06-26-2016 10:11 PM
  1. Samsung Galaxy S III Mini?!
    Last Post: 09-04-2014, 05:25 AM
  2. Some Cool Looking Stuff to Go with Your S5 Active
    By clitrenta in forum Samsung Galaxy S5 Active
    Last Post: 08-31-2014, 12:47 PM
  3. Replies: 1
    Last Post: 08-28-2014, 02:35 PM
  4. Android wear with Galaxy Note 3
    By Armthah0meless in forum Samsung Galaxy Note 3
    Last Post: 08-28-2014, 01:26 PM
  5. Huawei G6-L11 (LTE/4G)
    Last Post: 08-28-2014, 01:25 PM
