I've been using an iPhone for years. Basically because the thing just worked. A few weeks ago, when faced with the iPhone6 upgrade, I decided to jump to a Galaxy S5. This might have been a mistake.
I've been using a Galaxy Note 8 tablet with an older version of android (AT&T refuses to update it, which now turns out to be a good thing), and I really love it. Far more than I loved my iPad. Using ESfile explorer, I could get to everything on the tablet, and connect to any PC in my house and move files to the device and, more importantly, to the SD Card.
I'd heard about the issues with KitKat, but misunderstood, thinking that it meant you couldn't run aps from the SD card, not that NONE OF YOUR APPS COULD MODIFY THE DATA. My bad -- should have done more research, which meant I probably would have stayed with a crippled device I'm familiar with -- meaning an iPhone.
I won't rehash the old arguments about why google made such a brilliant/idiotic move. Instead (if you've read this far) I have a couple of questions.
The stock file program will write and modify data on the SD card, which is of nominal use, since I can't use it to connect to my network. ES File Explorer won't though (even though it says it will), and I wonder if it's because I installed it on the phone instead of the SD card. I might try and move it and see what happens.
My main questions are as follows:
On my tablet, I have DoubleTwist installed on the tablet, and it reads the songs off the SD card just fine. Any one know if that'll work on the S5? I ask because I plan to use the iTunes xfer for my play lists on the phone, but if DoubleTwist doesn't work, then I won't bother.
Rooting:
I read some articles on rooting -- specifically using towelroot I have an AT&T Galaxy S5, an I think the app has been updated to work with that. But I've never bothered to root a phone before and I'm wondering if anyone has any words of wisdom about dealing with a rooted phone.
I really wanted to like my android phone, but between the overheating issues (which I *think* I've solved), the low battery life and now this SD card issue, this might be my last droid phone. Which would be annoying, since I love the android tablets.
Thanks.
Rooting:
Thanks.
