If u try and disable some of these apps they ask u to uninstall the upsates to?
Is this Correct if not please can u tell me what im doing wrong.
Thanks.
Unfortunately I was one of those people who didn't get even a half day before having to charge again.....so I got to looking on the Internet and I couldn't find any real fixes....so I decided to fix it myself....I noticed that android system and android OS were extremely high in battery drain so I found out how to fix it.....all you need to do is disable a few apps....I'm posing pictures of all the apps you need to disable. I found that the Samsung link platform was causing it not to sleep the most but so we're the others. After disabling them...my android system and android os battery drain problem was fixed. Let me know if it worked for you
