hi,
so i read you can use s6's touchwiz on the s5 (as long as it's rooted). has anybody ever done this? if so, performance issues?
also, does that mean you get the software features on the s6? for example, i know the s6 has the newest version of multi window (based on the note 4's) where you can minimize appps into floating icons and where the camera and calculator are also multi window apps.
