Its a new device and i'm worried a about the battery, does it look like i need to get another one or does it look good?
It won't let me post new pics =/
Can people still view this post? Who deleted it =/ _--_
It would've been better to respond in the other thread you had created and which I responded to as well, but since you posted screenshots here, we'll continue here. Please make sure to Reply to this thread, not create a brand new thread, which will only cause confusion--thanks!
I'll repeat here what I had written in that other response, and please try to show us all requested screenshots, so that we can do our best to figure out the issue:
Charge up to 100%, then let it drain to 20-30% (note that this means battery down to 20-30%, not down to 70-80%) with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
Hi, its already down between 20% and 30%. Are this the screen shots that you need?
