A
AC Question
So, I just returned from a business trip and my Galaxy S5 (on verizon) with android 5 installed now has problems using my home wifi. What it does is it will connect to my router just fine but I will have insanely (think dial up) slow connections to the internet both in apps and in chrome browser. I can do speed tests on the phone and have no problems getting 50mb/s download and 6mb/s upload. I can ping the phone from the computer, I can even access my router through the phones browser. All my other devices in the house have no problems and nothing has changed on my router. Now here is the weird part. I can turn on my guest network on the router and the phone has no issues what so ever. My only consensus is it must have something to do with the security of my normal network, since the guest doesn't use any. But I have been through everything in the router and no luck. I have forced the phone to forget the network and reconnect it, I have cycled the power, I have forced it a new IP address, & I have cleared the cache, I really don't want to have to do a factory reset on the phone if I don't have to, especially if it won't work.
I have a cisco linksys E4200 router with the latest firmware, set to DHCP, I presently have MAC filtering off (had it on at first), using channel 4 (was the least congested). Any assistance would be really helpfull.
Annoyed in Colorado.
