Upgrade questions from HTC M8
I currently have the HTC M8 in 32gb. I have had zero issues with my phone. My wife and her sister have the same and both have had theirs replaced for hardware and software issues. Im the lucky one. Only issue I have is the blinking LED is dimmer compared to my wifes.
I really like the S6 Edge + and it seems it would fit me well. I was tempted to switch back to the iphone 6+ plus next month but thinking Android is the way to stay.
My concerns are the following.
1. Is 32gb enough? I have not used even 16gb on the HTC and do not use a SD card now.
2. Been hearing that Verizon is going to block Samsung pay on the Note 5 so are we safe to assume this will be on the Edge as well?
3. Samsung has rumors that after a few months the phone slows down. Think this will happen with this phone as well given the specs (extra ram)?
Not sure what else to look at here but these are my concerns I am hoping some can address before I pre-order with Verizon later today or tomorrow.
Thanks
Thanks
