I have the fast wireless charger from Samsung as well, so this review is a little comparison of the two.
Samsung fast wireless charger:
PROS:
- quality stuff, something you'd expect from a big manufacturer.
- internal fan? not sure if this is a pro or con, but it helps to keep the charger a bit cooler
CONS:
- you could probably hear the fan noise if put next to your bed at sleep times
- expensive at $60-$70, depending on color and merchant.
- only works with the Samsung adaptive fast wall charger, does not work with other qc 2.0 certified wall chargers.
Choetech fast wireless charger:
PROS:
- much smaller in overall size, I like it better than the bigger Samsung one.
- no internal fan or vents. although this could be subjective, only time will tell if there would be a heating issue.
- at only $35 compared to $60-$70.
- works with all the qc 2.0 and Samsung adaptive fast wall chargers.
not really any cons for the choetech, it's much cheaper and works just as well as the Samsung. it even works with all qc 2.0 wall chargers, and that's a big plus. so I really don't see a reason to buy the Samsung unless one is into the big brands.
for the record, I have received this product at a discounted price in return for an honest review.
PROS:
CONS:
PROS:
