It's been a week using edge plus and it's been awesome. However today I noticed a slight detoriation in camera quality. And then I noticed the IR sensor is not flickering red as it used to earlier.
I have recently upgraded software via OTA
But not sure if it happened after the upgrade.
Now focusing in low light is also not possible without flash. Please guide me if it's hardware issue or software , I mean is there a way to check the same
