S6 edge and Xmod
Status
Not open for further replies.
Ronnie Tyler
Hello everyone this is my first post I'll get right to the question
I have an S6 edge I want to use xmod on it I tried the method where you root the phone first then use lucky patcher to convert the xmod app to system app I did the method on note 3 version 5.1.1 and note 4 5.1.1 for my friend and the xmod worked but when I tried to do the same method I didnt work the problem I'm facing is whenever I try to convert the app to system and after the reboot the app doesn't i appear i tried rebooting it several times then i downgraded the phone to 5.1.1 and tried the method it didn't work then i download a firmware from sammobile i thought maybe on another firmware it will work but it didnt i tried another firmware and it didnt work then i tried the method of root explorer copied the app to system/app and that method didn't work either so if you anyone of you could help me I'd be really
Status
