My phone started saying process system isn't responding. Do you want to close it? You can either hit yes or wait. The phone gets slow, stops doing what it is doing. The battery is now draining in 2 hours with me doing nothing. I uninstalled all the apps I installed in the past 2 weeks. I cleared the cache in all apps I use frequently use. I cleared the cache for everything. It won't stop. How can I fix this before I throw it through a wall?!?
