Fast charging not working !!! Even after changing the charger multiple times
Slim 1
Fast charging works once out of 100 times its rare but sometimes after I unplug and plug again continuously until it works I changed the cable and adapter (with original ones) they both worked (fast charging) at first but I faced the same problem with time ( few weeks ) I need help bcs Im so tired and unpluging and plugging is damaging my battery life.... pleaseeeee help me ( my phone is samsung galaxy s6 edge plus ) 😭 HELP is it because of phone?
Tim1954
Q&A Team
Jan 17, 2016
6,924
I'm not a fan of fast charging to be honest. The device will have safety built in and will choke the charger if it's getting hot or drawing too much current.
That said, you may have some issue in the regulating section in the device. The usual wipe cache partition and reboot the device should clean out the cobwebs and refresh your device...
At the very least, reboot it daily...
Phantom3SE
