1. Bignizzle2015's Avatar
    How to remove the white software update box under settings above quick settings on S6 Edge Plus g928p? You can x it off but when you close settings app completely off and open it back up, it shows up again. There is also a 1 showing beside system update option under settings app too. It never goes away and I have deleted the update in the fota folder. How can I clear the white box? S6 Edge Plus g928p 6.0.1 Rooted Thanks
    02-06-2017 05:21 PM
  2. B. Diddy's Avatar
    Moved from the Marshmallow forum to the S6 edge+ forum.
    02-07-2017 02:35 AM
  3. Bignizzle2015's Avatar
    03-11-2017 05:59 PM
  1. Replies: 1
    Last Post: 02-07-2017, 11:23 AM
  2. How to turn off suffle in music play back galaxy 6?
    Last Post: 02-07-2017, 06:38 AM
  3. Replies: 1
    Last Post: 02-06-2017, 08:11 PM
  4. Replies: 0
    Last Post: 02-06-2017, 04:43 PM
  5. Replies: 1
    Last Post: 02-06-2017, 04:34 PM
