Eddie ortiz1
I had the same problem I recently received the s6 edge plus from Best Buy and it came with the Samsung wireless charging pad.it will not charge past 10 minutes without a problem charging.the problem is solved now after going to Samsung pay when I went to set up the account it asks to update. with the software update also had a system update. once it updated the Samsung pay and systems i had no problems with the wireless charger. I set it and it changed all night.. hope this helps
