I posted this on the regular S6 forum but just in case people with edge are not going to the regular S6 forum I decided to post the same here.
I'm going to ask this again as it seems that every time I ask it gets buried under hundreds of new threads and sadly, most of those are asking the same.
Besides, turning off Smart Network and Scanning Always Available, both on Wifi Settings, and turning off Wifi Calling (turn it on only when needed) and VoLTE, can someone that still have the Cell Standby drain check your wifi settings? I mean, I have posted this a couple of times and just 1 have tried it (Almeuit) and confirmed today it was a lot better than before, but check if your Wifi router is 2.4 or 5Ghz, if you have both, just set your 2.4Ghz connection or force your phone to connect just to it. See what happens after a couple of hours.
