On my Note 4, this feature is very handy when my hands are dirty. Where can I activate this feature on my new S6 Edge? Thanks!
You're right, I think it was called air gesture. Bummer, it was such a handy feature. Thanks though!I believe Air Gestures were eliminated in the S6.
Update: Silly me, the "hand wave gesture" feature does work. You can find it under Accessibility---> Dexterity and Interaction ---> Gesture Wake Up.
One of my favorite features that allow you to turn on the screen just by waving your greasy hand across to see notications, time, etc. without touching anything.
Thanks. You can try for a few days, and can always disable it. For me, it never wakes up accidentally as I think it only works when the device is laying flat as opposed to in a pocket.Good eye ! Does this lead to a lot of accidental wake-ups though? Would be nervous using this with a phone that already has so-so battery life
