miryaghoub
i have try all the ways.changing the cable-rest the phone and all the carzy ways.but it still dosnt work..help me .what should i do?
My friend had the same issue with hers, and I was texting her trying to figure it out. Everything found just seemed to say make sure it's plugged in all the way. So I plugged mine in halfway into the block and plugged into my s6 and it said cable charging. Then pushed it all the way in still cable charging. Unplugged it a couple times still cable charging was like great I broke it. The. Came across a note 4 post guy was like unplug the block and disconnect the USB. Connect the usb into the block and them the block Into the wall then plug your phone in that ordsr and it'll work. I did it and my phone fast charger. No word on my friends lol I just bought her a wireless charging pad but seems its the blocks cause everythinf samsung posted "make sure it's plugged in all the way." I haven't had issues since and my phone fast charges screen on or off
I've had my edge for a few days now and everything has worked fine. Today however, fast charging is not working. Just went to plug it in and it said six hours until fully charged. Thought it was just because it was at 6% and need some more power or something to start the fast charge? Doesn't seem so. I tried different wall outlets and it's still not fast charging. I am using the charger that came with the phone. It's charging so incredibly slow. Please excuse the way I wrote this, I'm incredibly tired.
Saved my lifeOh, right! That too! That happened on my Note 4 a couple times... thought I had broken the charger (because it will still charge normally, just not fast) and then I just pushed the cable a bit further and voila!
I did want to post that fast charging can be turned on/off. Go to device maintenance, battery, then tap the 3 vertical dots in upper right corner for advanced options/setting. That's where the switch is.
