How do I turn on the grayscale effect on my Galaxy S6 Edge?
  • Start date Start date
A
AC Question
how to turn or greyscale effect on galaxy s6 edge
i have been trying diffrent options to extend battery life and read online about turning on greyscale via accessability and hit home button 3 times however the webpage i was reading said nothing about turning it back to normal and i can not for the life of me figure out how so any advice would be welcome
also any tips to extend battery life that work that will avoid my usuage being effected welcome too
thx in advance
Re: how to turn or greyscale effect on galaxy s6 edge
Settings > Accessibility >Direct Access > Grayscale
havent seen it on a friend s6 edge, but my s5 has an option for greyscale in power saving settings
and ultra power saving also has greyscale.
both using 5.1.1
I added it to navigation bar, for easy access, U. Power save mode
"It will be mine. Oh yes. It will be mine."
Okay I have LG G5 and I have restore and resetting as well as troubleshooting to see what is causing my battery drained. Have anyone notice that it might be Grayscale? History: I have turn off most sync email, notification, NFC, GPS etc. but at the end of the day I'd still see big battery drained then default state. But here are what I'd have active, two widgets G-Task and Calendar, 5 email but only one sync fully while all other only have email. Shot cut to Line app, facebook via website shortcut not actual app.
slackingfred
