Has anyone noticed that when using Nova on the S6 edge, when setting up widgets, they are badly squished and truncated. resizing them only squishes or exaggerates the distortions. These are standard widgets, for instance the beyondpod widget cuts off part of the title, but same widget on touchwiz is fine.
Its like Nova is blowing widgets up larger than they should be.
Ive tried changing the desktop grid sizes, the icon sizes, nothing helps.
