OFFGRID™ BATTERY/SD Card CASE Samsung Galaxy S6 edge
Cool idea. Seems to add a lot of bulk to it, but understandable considering what it does.
That's a great looking case with an ability to expand memory. If anyone picks this up let us know how it works and if you like it.
I wonder how reliable will the memory be...not actually connected to the device I wonder if it will corrupt often...
Posted via the Android Central App via my S6 Edge
That is a good question, I imagine it will be connected to the device via OTG.
I just got mine in the mail for my S6e. It's a nice case, supports fast charging. The SD card works very well. I like the front facing led lights.
The snap on front ring not snap closed all the way, it's not a snug fit at the top of the phone. I'm was worried about the unifit case for the S6 and S6e, it definitely detracts from the S6e aesthetics. The Mophie has a better look, keeping the aesthetics of the S6e phone.
I love the features, but am disappointed in the aesthetics on the S6e. I think case would be better for the regular S6.
Updated: I just noticed the additional ring for the S6e version in the packaging , whoops! Now the fit is good! I'm happy and would suggest this case over the Mophie. I'll be testing the battery, but so far so good!
RohitPatidar57
