I've received my second s6 edge 128gb in black sapphire and they both have a 'problem' with the screen.
I say 'problem' because it's not so much of an issue, but none of the phones I've owned have had this issue before.
If I look at the s6 edge under lighting, I can see a dark line about 2/3 of the way from the left edge. The line starts about 1cm from the bottom of the screen and is around 4cm in length, going straight up. At first I thought it was a crack but the screen is perfectly fine when on and is only visible when the screen is dark and you're viewing from under a light source. The glass is fine and the blemish appears to be under the glass.
Does anybody else have this problem or should I send the phone back yet again?
