Hello
i have the s6 edge sm-925f, today i was using snapchat and suddenly the phone turned off
when i turned it back on it was stuck on samsung screen
i didnt update it or root it or anything
and i also cant access the recovery menu when pressing home power and volume up
i tried to install new software downloaded from sammobile using odin, but still the same problem
what should i do? thx
