And besides that its getting quite hot. Gsam battery monitor shows it reaching 95-100 degrees frequently. And then there are times where I'll be either browsing in the Web browser, doing things with an app, or toggling between home menus to get to what I'm looking for; it'll frequently either freeze there, or it will screen time out regardless of me trying to move through the menu/windows/etc, screen will go black, and pressing home key or power button will not do anything. I have to hit power and blume down at the same time to bring up the boot menu, select restart normally, and after that it will do as its supposed to for a while. But then it goes back to getting hot again, going unresponzuve, and I have to repeat the power+volume down method to restart it yet again
I thought perhaps maybe there was an outside chance of malware being on it, so I tried 3 different scanners to see if they found anything, those AV scanners being avast, Norton mobile, and Kaspersky mobile, none of them turned up anything, more did they find any issue with installed apps 'misbehaving'.
Is this to be expected now that my sevice is over a year old, or could there be some hardware internals messed up causing this? It sure is frustrating. Battery drain is pretty significant too, after no more than moderate usage, it's down from 100% to 20% in about 3-4 hours. It's frustratingoing. Of you have any suggestions, I'll be happy to try them. Otherwise I'm thinking of doing a factory reset if I can't find any solution.
