Good afternoon!
So I've had the S6 edge for a little while (since October 2015) and I had an issue suddenly come up a few months ago. I couldn't find a solution at the time, and Samsung were less than helpful when I went to them.
Basically I noticed my Fast Charge stopped working one day so had a look at forums and came to the conclusion that my cable might be the problem. So I ordered a new cable and adaptor (just in case). They arrived, tried the cable... tried the adaptor etc and all to no avail!
I decided to back up the phone and try to wipe the software... however when I went to plug it into my computer it came up with the old USB Device Not Recognised error. Read up that I had to update drivers etc, so did that, but it still kept coming up with the same error!
Hardware diagnostics have been carried out, software has been wiped and re-installed etc and still no solution!
Does any one here have any ideas or tests I can try out?
Thanks!
VJ
Thanks!
VJ
