I have a Samsung S6 Edge sm-g925v that had a cracked screen and blown digitizer. I replaced the digitizer and screen and everything seemed fine. the phone booted up started applying updates and downloading the latest firmware (The phone was sitting on the shelf for about a year). Once the firmware was downloaded it asked if I wanted to install the latest update so I did and when it restarted it went into a boot loop. I have since wiped cache and preformed a reset to default as well as flashed the it back to and older version of the firmware downloaded from sammobile. Nothing seems to work. The phone starts to boot and at right around 1 minute and 7 seconds it will restart. it is always 1 minute and 7 seconds. Any help would be great.
