Does the Galaxy S6 Edge work while the phone is locked by a password?
A
AC Question
galaxy s6 edge
Does the "edge" on the galaxy *s6 work while the phone is locked by a password? *And also is there a flash on the front facing camera. *Thanks!
SnowSanta
69
Re: galaxy s6 edge
And the edge does not work while locked. Well, you can press it, but nothing happens, like if you press a different phone it normally says swipe up or down. So, if you particularly say: does it work. --> No
