anon(9409134)
Happy to say that cell standby doesn't even show up under battery usage anymore must've been the push service
Like I mentioned in an earlier post here I'm following the 40-80% charging cycle approach so posting my battery stats would be little confusing.
Today I went to the full battery charge (will do it 3 or 4 times a month) and obviously that way is better to understand the battery stats, so here are my battery stats for today, everybody getting better, add is averaging about 6.5 hours of SoT, one thing though, I haven't used Bluetooth today with my Asus Zenwatch and Android wear.
View attachment 172418 View attachment 172419 View attachment 172420
I have followed most of your advice, Erasat. However, I have the screen brightness turned way up. And still, I'm getting WAY much better battery life. Thank you for all of your tips. I'll bet if most people follow your advice, they will, too. This phone is definitely a keeper - and before reading your tips, I was so frustrated that I was going to take it back and probably get the Note 4.
Those who are getting really good screen on time - what are your brightness settings? Do you guys keep it at the lowest brightness or something?
Does disabling S Health do much? (If it can be disabled)
It just seems like it would use some battery because it tracks steps 24/7
Appreciate the help, thank you, thanked your post. It's just a shame that it's necessary, and that thousands of people who don't hang out in tech communities won't be privy to it.
Hey do you have an suggestions for what services we can disable also? I have used all of your tips and got creat screen time yesterday. Almost 5 plus hours of onscreen time. Heavy YouTube, twitter and Instagram.
Thanks!
Try what I didn't mention in my initial post but always do to all my phones and the last post before yours suggested, and go to your Accounts (Samsung, Google and others) and under the Sync settings just turn off sync for all the services and apps you don't really use.
Besides that and the things that I already posted everything else is very personal, you are the one that know what you'll use and what you won't. But just in case you need some references, I posted some screenshots of the Apps I disabled on this phone, those for me are just Bloat and will never ever use them.
Have you thought about updating your original post with these recommendations? It seems that many people are using it for reference, and this is a key point. The other point to make is that the recommendations to disable certain apps is not to cripple the features of your phone, but to limit resource use from multiple redundant apps (weather, news, social networks, email, calendar, search/voice recognition, cloud services), the many versions of which all run in the background simultaneously.
