Yeah, I wonder why yours says that. This is what mine shows View attachment 171435
Location off completely is the best. Second is the WiFi / network.
I wish there was a setting so you could do the most power efficient setting for things like Weather where an exact location isn't needed and you could only use the GPS when exact location is needed like for Navigation. Anybody know of a way of doing this?
I would turn location off, but I need it on so the weather on my widget can update
This! That's what I've done.You can set the weather to one location like your home town and have it updated every hour or two or three without having the GPS on at all. The only draw back is it will only update it for that one location. That's how I have mine so I can have GPS off.
Sent from my SM-G920V using Tapatalk
