So I got a Verizon branded Galaxy S6 on launch day from the corporate store. On that day the battery started getting warm to hot a lot so I went back to the corporate store and talked to the same guy and he said that it was not warm or hot and did nothing for me. So from that day I been seeing it get warm to hot a handful of times and I even asked other people if it was like that to make sure I was not going crazy and they all said yes. Then on top of that I started seeing the battery drain very quickly when I was using it or on standby(with everything closed out). Then through out the the day I have to charge it a few times because for example if I take it off the charger at 100% 3-4 hours later I would need to charge it again.
Then with the Wi-Fi what is going is I have my mobile data off and I'm on my 5GHz 120MB home privet network and everything is not loading at all and apps like Chrome, Facebook and Instagram(just to name a few, but everything that uses internet can't connect at all) all tell me that it can't connect to the internet. This has been going on since yesterday and has not worked since and when this happens it tells me my signal strength is very strong(866Mpbs). I just spoke to Verizon tech support today and they told me to go to the store even after I told them I did like I said before, so with this being said I want to know if any one else is having these issues or it is only me? I herd the Note 3 & 4 on 5.0 is having the same battery issues, but I haven't herd anything about the S6 being part of that. Also, what should/can I do to fix theses issues(if anything can even be done) or what advice can you give me regarding this?
