doesn't let me upload any images.
Overall, the last 24 hours weren't too bad, but some of the numbers still seem off.
23h, 7m 7s on battery
Android OS 23%
Google App 16%
Email sync 13%
Android System 8%
Cell standby 6%
Chrome 6%
SOT was about 2 hours
Isn't it weird that my screen time doesn't even make it into the list? I hardly ever get more than 2.5 hours and it surely is never on the top of the list. Would camera use by reflected in the Android OS number? There is no way I would ever be able to get 5 hours SOT with my current numbers...don't consider myself a heavy user, actually. The above was more or less with Wifi turned off since I was travelling.
2 days ago, my cell standby went up to 30% within literally 10 minutes...anyways...any additional advice is more than welcome, otherwise I'll try the replacement strategy.
With that amount of Android OS consuming your battery it may be one of the services such as Location (GPS), Bluetooth or even NFC if you have them on all the time it should be that or something about that, try turning them off for a while, at least NFC and Location (GPS) and compare your battery life after a couple of hours.
Like I posted on my thread about tweaks, having all this services all the time won't benefit too much. I always turn all of them off and just turn them on when I need them, that's what the Quick toggles are for, even every manufacturer suggest us to use them this way. But if you need your locations on, try using one of the options that draws less power, not the one that uses the most, with NFC, there is no reason to have it on until you really need it, and for Bluetooth, I use it all the time because I have a Smart Watch and if not I'm at my car or at home with the headphones, so you should know if you need it on or not.
If you don't have those services on then definitely is something else, and I'd say that you should consider just doing a Wipe Cache partition in recovery Mode, and see if it helps, if not, then the Wipe data/Factory reset option also in recovery mode, just be sure to do a Full backup in Samsung's Smart Switch so you can at least restore most of your stuff back.
