I usually assigned one of those to the gestures Nova Launcher on my m7. Does anyone know an alternative so I can direct dial with Nova gestures?
If you're running the beta, it seems to have lost shortcuts. I went back to the stable version.
You're looking to have a gesture trigger a direct dial?
Or you're looking for an app to put a direct dial on the homescreen?
The Web is full of S6 owners complaining about this. It's very strange that Samsung took this feature away. Some people recommend this app.
https://forums.androidcentral.com/e...details?id=klozin.ShortcutDial&token=Lj-sOooo
Worth a try. I imagine that you can link your Nova gesture / icon swipe with it. Report back how it was.
Does it work with the Nova gestures? Some of the reviews mention it is not compatible with Lollipop.I found Better Direct Dial which did the trick.
Thanks to all that tried to help.
