Hi,
Have owned the S6 for a few months now and everything has been running great however in the course of a week, two separate (seemingly unrelated) issues have arose. The first issue is ads popping up on my home screen sometimes in app, home etc. this happens at roughly 10 - 15 minute intervals. They are large and state that they are provided by google. When clicking on the ad it takes you to the app in the google play store.
The initial pop up ad.
The application that is running it using the button in the bottom left of the phone.
I have tried deleting recent downloaded applications and have run AVG malware detection.
The second issue is around wi-fi connectivity. If i come home from work my internet will not work despite my laptop, PS4 and tv all connecting to the internet. It states that i need to log in-to the secured network. If i click on this notification it moves to a page where about one tenth of of the bar loads and sits there not doing anything else. There is then 3 dots in the top right hand corner, when i click on this and select login with network as is, it does nothing. If i then open a web browser it will not load anything at all. Where as 4G network loads immediately. I don't have any photos as the notification hasn't popped up since writing this post.
I live in Australia and am connected to the Telstra network. Any advice or help is greatly appreciated.
Thank you.
Thank you.
