erasat
Anyway to respond to the rest, 30% is still a pretty significant concession to make unless your use is mostly indoors in dim lighting. It also tends to make the display less vibrant. I understand that those conditions are something you've stated you prefer otherwise you get headaches, but that doesn't apply to the norm. Therefore my prior statement still stands. A couple of you keep defending methods of making compromises as one poster just recently put it, "these are things you must do with Android phones" (I'm paraphrasing). I disagree with that blanket statement. It would be far more accurate if he had stated "these are things you must do with certain Android phones with questionable battery life".
I said it earlier and I'll say it again. Android phones using current battery tech are simply not ready for great battery life if they're sporting qhd displays and the most recent OS version. Until new battery hardware gets introduced, and Google learns how to combat the persistent battery drain gremlins in 5.xx I will at least attempt to stay with 1080p models if they continue to be available.
It was me who said that and I really don't understand you when you say that I need to say that it's only for some devices but then say that Android devices using current battery tech are not ready for great battery life if using qHD displays. If you do some tweaks uninstalling bloatware and disabling unused services and apps that most android devices and ALL Carrier's models come with, you may get great battery life.
Buying a S6 with 2550 mAh battery and a S6 Edge with 2600 mAh battery with a qHD display and pretending to get Great battery life without any tweaks is simply impossible, again, some tweaks must be done, tweaks not compromises, big difference. That is one of the simple thing you should know before buying a device, complaining after buying it just say that you didn't do your homework before buying.
BUT again, today I received my S6 active, a 5.1 qHD display with the best battery life on any Android Device right now, and according to some articles I've seen even better than the 6+. So yes, they are devices with this displays with great battery life, and even better with the normal intelligent tweaks mentioned above.
Imagine if I think that the S6 is the best Android device right now that after 10 android phones in the last year, from Motorola, Sony, LG, OnePlus, HTC and Samsung, I currently have 3 S6, a day one S6 Edge, Unlocked International Blue Topaz S6, and a brand new White camo S6 active. Best 3 phones I've ever owned.
