Samsung Keyboard Case
NickinVA
59
I know... I know, but I really miss a physical keyboard sometimes.
Showed up, and doesn't work at all. Is there some trick to enable it? No instructions at all. Thought maybe only worked with TouchWiz (I'm running Nova), but no dice.
Guesses?
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Guesses?
Make sure the device is properly installed. Also, try a reboot and see if that helps. keep is posted.
NickinVA
59
When you say "installed" - you mean physically? Yes. Pretty hard to screw up. The case part fits flush, and the keyboard snaps right in. Only thing I can figure is if there's some magnet trigger that isn't functioning the way it should to tell the phone that the case is on. Will definitely keep y'all posted.
vferrari
331
I don't have mine yet, but my understanding is that it won't work unless you have the default theme selected.
kemberley1
