Hey guys, anyone know if theres a waterproof case out there for the s7 edge? I would go towards life proof but they don't make it for the edge. If anyone has some suggestions, please let me know, thanks!
It's already IP68 rated! Why used a waterproof case lol
Yes you do. If you plan on using it near a pool with more than 1m depth. Or if you plan to go with it boating. The phone can only stand clean water. Once you go pool with chlorine in it, or salty water with all sorts of solutes on it, the water resistance capability drops quite a bit.Really no need for a waterproof case with the IP68 plus I'd doubt you would find one because of the curved screen
Well then you should get an s7 and a lifeproof case. Case manufacturers are having issues making cases for the curved screen
