I was a Note 7 owner, and as of Wednesday I should be a S7 edge owner (if my phone is shipped and delivered on time). Back with the Note 7 I was contemplating purchasing Samsung Level U Pro wireless headphones. I never ended up pulling the trigger on the purchase, and now I'm considering them again for my s7 edge.
For anyone who has owned or used a pair would you recommend them?
Currently there is a $28 price difference between the ANC (active noise canceling) version and the non-noise canceling version. Anyone use both, and have opinions about the positives or negatives of each? For $28 difference it seems like it might be worth the step up to the ANC version...
Any thing else you'd recommend instead of the Level U Pro? (I've been leaning toward the Level U Pro because of the UHQ Audio since that works with our Samsung phones.)
Edit: Well Best Buy made a major screw up. On the day my phone was supposed to be delivered by them they sent me a, very cold and lacking in information, e-mail that my phone has been delayed by 30 days. Huge failure on Best Buy's part!
