[ROM][STABLE][G93XF/FD][OTA][ROM-CONTROL] KING_ROM_S7_EDGE_V14 [bpj7]
Jul 27, 2011
13
LATEST FIRMWARE NOBRAND
ANDROID 6.0.1
SECURITY PATCH MAY 2016
RELEASED 03-05-2016
DEODEX
ZIPALIGNED
ROOTED 2.71
BUSYBOX
ADD SUPPORT TO S7 FLAT VARIANTS
DISABLE SIGNATURE CHECK
YOU CAN INSTALL OLD APP OVER NEW
TRAFFIC METER IN STATUS BAR
OPEN ALL TOGGLE ON RIGHT SWIPE IN STATUSBAR
DEFAULT WINDOWS ANIM. x0.5
VIRTUAL LOCK BUTTON SET TO LEFT CORNER STATUSBAR
ENABLE OUTDOORMODE IN SCREEN SETTING
ROUNDED NOTIFICATIONS IN NOTIFICATIONS PANEL
REMOVED GREY BAR WHEN ENERGY SAVING WHAS ACTIVED
REMOVED WARNING SAFE VOLUME
ADD SBROWSER SECRET MODE
FIX PERMISSION FOR EXT SDCARD
SQLite3 OPTIMIZED
RAM OPTIMIZED
ZIPALIGN AT BOOT
KERNEL INSECURE MODE
FULLY SUPPORT FOR INIT.D SCRIPT
3 MINIT BATTERY MOD
POTATO CLOCK
AVANCED REBOOT MENU
DPI SCALING IN SETTING/DISPLAY
TOUCHKEY LIGHT DURATION IN SETTING
SMART MANAGER DUAL LAYER
ADD SAVE/RESTORE SMS IN MESSAGE APP
ADD DATA USAGE IN NOTIFICATION PANEL NEAR AUTO CHECK
GEAR VR FULLY WORK
ADD SAMSUNG MUSIC PLAYER
ADD ULTRA DATA POWER SAVING IN SMART MANAGER
REMOVED EMERGENCY BUTTON IN POWER MENU
MULTIWINDOWS VERTICAL SCROLLABLE
ROUNDED RECENT PANEL VIEW
ADD QUICK LAUNCHER IN RECENT APP
6 TOGGLE IN A ROW
RAM BAR IN RECENT
KNOX REMOVED
MICROSOFT APPS REMOVED
FACEBOOK, INSTAGRAM WHATSAPP REMOVED
GOOGLE MUSIC REMOVED
DUAL SPEAKER V16
ALL APPS MULTIWINDOWS
REMOVED SD NOTIFICATION AT BOOT
FASTER FIX GPS
MULTI FONT
YAHOO PANEL EDGE
MORE SOUND NOTIFICATIONS
DIRECTORY FOR ZIP MOD in /sdcard/KING ROM S7 EDGE
XPOSED READY TO INSTALL (/sdcard/KING ROM S7 EDGE)
DISABLE ANTIMALWARE
ADD 100 CONTACT QUICK CALL
TOGGLE SOUND CAMERA IN CAMERA APP
CAMERA WORK DURING CALL
CAMERA DONT STOP MUSIC
EXIT BUTTON FROM SAMSUNG BROWSER
NATIVE CALL RECORDING
CALL QUALITY IN HD
ADD CALL BUTTON IN CALL LOG
ENABLED VoLTE FOR SPECIFIC CARRIER
MULTIUSER
BEST QUALITY OF STREAMING
KING BOOTANIMATION AT 60 FPS
ENABLED SEARCH DIRECTORY IN ARCHIVE APP
DISABLE CONVERSION SMS TO MMS
ADD MEGA ADSBLOCK
INCREASE BATTERY LIFE
INCREASE PERFORMANCES
ALLOW MOCK LOCATION
ADB FULLY WORKING
OTA UPDATER
KING_ROM_S7_EDGE
@Chainfire - For SuperSU
@SuperR. - For Kitchen
@svadev - For DEODEX tool
@zubi182 - For Dual Speaker mod
@Tkkg1994 - For adb fix, updater-script and efsbackup
@Ticklefish - For Tickle My Android
@raziel23x - For APK Multi-Tool
@metaspook - For Viper4Android
@Modaco - For ota updater
@daxgirl - For Rom control
@Enriquezdelaplaya - For beta test
@proofer - For beta test
In /sdcard/KING ROM S7 EDGE we are some mod to flash in recovery for install or remove XPOSED, DUAL SPEAKER, SuperSU...
PRE-REQUISITE:
Recovery TWRP
Encription Disabler
Root
INSTALLATION:
1. Download Rom
2. Reboot in recovery
4. Click on "advanced wipe" e select "dalvik cache", "cache", "data" and "system"
5. click on "install" e select the ROM
6. First boot during about 8 / 15 minuti, Relax...​
Re: [ROM][STABLE][G93XF/FD][OTA][ROM-CONTROL] KING_ROM_S7_EDGE_V6 [ape9]
From now, all the mod, bootloader, modem and much more inside my Rom, will added to my app, please download it for manage the Rom, also you can request personalizations from it
Re: [ROM][STABLE][G93XF/FD][OTA][ROM-CONTROL] KING_ROM_S7_EDGE_V10 [apg6]
Does this mod have Wifi Calling? I have an SM-G935F S7 and have no option for wifi calling, despite my carrier (vodafone) having enabled it. Thanks.
depend of CSC, choose the correct csc and all tweaks are enabled
Re: [ROM][STABLE][G93XF/FD][OTA][ROM-CONTROL] KING_ROM_S7_EDGE_V12 [bphj]
KING ROM S7 EDGE V12 ONLINE
YOU CAN FIND IT IN PRERELEASE IN MY APP:
HERE THE CHANGELOG:
onknknight
