N Note8uzer Well-known member Jun 20, 2016 315 0 0 Visit site Mar 24, 2017 #1 Hi, Just wondering if there is root for the S7 Edge with Nougat.
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,595 4,737 113 Visit site Mar 24, 2017 #2 Moved from the S7 Active forum to the S7 edge Rooting forum.
A AnnaEdd New member May 9, 2017 1 0 0 Visit site May 10, 2017 #3 The best and easy way to root your S7 edge is just open this link This is How to Root Samsung Galaxy S7 and S7 Edge, follow the steps and your problem will resolved.
A anon(631531) Well-known member Jan 5, 2012 1,586 11 0 Visit site May 11, 2017 #4 How do you know if your model is using Snapdragon 820?
LineKill Well-known member Dec 24, 2011 1,801 0 0 Visit site May 13, 2017 #5 grunt0300 said: How do you know if your model is using Snapdragon 820? Click to expand... You can use this app. https://forums.androidcentral.com/e...pps/details?id=com.cpuid.cpu_z&token=1OMwjrVD Or here is a little chart.
A anon(631531) Well-known member Jan 5, 2012 1,586 11 0 Visit site May 13, 2017 #6 Found CPU-Z, and downloaded it. Will be going to xda-dev. for answers.
LineKill Well-known member Dec 24, 2011 1,801 0 0 Visit site May 13, 2017 #7 grunt0300 said: Found CPU-Z, and downloaded it. Will be going to xda-dev. for answers. Click to expand... That's by far the best place to go for rooting. Have phunツ
N Note8uzer Well-known member Jun 20, 2016 315 0 0 Visit site May 26, 2017 #9 So I can't root my S7 Edge if I have the Snapdragon 820?
N Note8uzer Well-known member Jun 20, 2016 315 0 0 Visit site May 26, 2017 #10 I read that I can't unless I am missing a new root for this.
