It is actually both. You can use either standard with the S7/S7E. It was that way with the S6
Yeah the s6 worked with both. This should be the sameIt is actually both. You can use either standard with the S7/S7E. It was that way with the S6
I had both for my s6 and found the qi to be more reliable than PMA. The PMA was way more finicky about placement and it would always disconnect.
