apple to android for first time ..ordered the S7 edge.
anon(9842641)
75
hi , just pre-ordered samsung galaxy s7 edge black . cant wait to get hands on . i am iphone user for long time , thought its time for the change .i used to have nexus 7 long back for a couple of months but not so familiar. so how would be the transition and all?
are there any apps to port everything from IOS to anroid.?
thanks
zainsikander32
66
Yes you can use Smart Switch by Samsung. It'll transfer everything. Welcome to the family! I hope you can convince others around you to make the switch too.
itguyjax8430
Retired Moderator
Mar 15, 2013
6,822
thanks
Welcome to Android Central!
STARGATE
Ambassador
Oct 8, 2012
6,660
62
48
Hello and welcome to the forums at Android Central!
There's always a learn curve, but if you give it a chance you'll have a great time with Android.
Lakes21
I too am an iPhone user since 1st gen iPhone. Ive made the switch to android for the very first time with the S7 edge and I must say that I am very happy with it. glad to be part of the android community!
jimbo1mcm
948
16
I go back and forth between Apple and Android. I have the 7Edge now and it is a far superior phone to the Iphone 6S plus. You will really enjoy the 7.
yomny Martinez
156
I also was back and forth between Apple and Android but i think i finally found my happy place. The phone is great, fits nicely in the hands and the camera is just great. Get samsung smart switch on your apple and it should transfer everything except apps that are not compatible from Apple store to Play store. Enjoy.
racingvike
17
My 16 yo son switched from the iPhone to the S7 last week and says he is glad that he did. After hearing him talk about how much he liked it my wife may be switching as well.
I can also confirm the transfer of data from iPhone to S7 using SmartSwitch was as easy and painless for his phone as it was for me going from the S5 to the S7 edge.
Ale Aguilar 62
Wow I think you just did a great upgrade. Try the app MobileTrans, to transfer all your iphone data to any OS (in case that you still need it). Maybe your first days using android where difficult, because all of the changes you see, but after that, you'll realize that you made the right decision, because you have most of the apps for free and also have a lot more variety. I hope that you enjoy your new S7, you can tell me later if it's a lot better than an iphone. Greetings!
wxman2003
282
Smart switch is a total disaster for macs. It doesn't work at all with my 2011 imac. Luckily for contacts having everything connected to google works. iSyncr works for transferring music. I really enjoy the S7 Edge. But if all you do is use apps, text and play video and music, there really is not much difference. Sure, you can put widgets on your phone but if you look at many screen shot photos of the S7 edge, they look like an iPhone.
http://forums.androidcentral.com/samsung-galaxy-s7-edge/647901-post-screen-shots-taken-s7-edge.html
Chelsea rae
