how do you guys feel about Samsung disabling that feature?
I personally think it's a mistake I would prefer to have that as an option I hate having to install apps and manually move the files to my microsd. Every time I update my apps I would have to go through it and manually move it again with adoptable storage that issue will be corrected. I really think the only reason why Samsung disable it has to do with performance they just don't want to admit it. I personally don't bother taking my sd out to drag and drop my files over how many of you actually do that? Also with all the bloatware that they install by default the adoptable storage makes sense.
